DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Batch Plot
11 REPLIES 11
Message 1 of 12
939 Views, 11 Replies
Batch Plot
Is there a way to batch plot drawing files with True View? One of our guys
wrote something that used Voloview, but it's not compatible with True View.
Thanks.
Margo
Margo dot Reppert at aps dot com
11 REPLIES 11
Message 2 of 12
John Schmier wrote a batch plot to DWF for AutoCAD 2007 but not DWG
TrueView.
http://dwf.blogs.com/beyond_the_paper/2006/11/batch_publishin.html
I have heard some people claim that DWG TrueConvert might batch plot to DWF,
but I have not tried this myself.
"Margo Reppert" wrote in message
news:5408453@discussion.autodesk.com...
Thanks.
Margo
Message 3 of 12
Scott,
I was thinking more along the lines of batch plotting dwg files with true
view. Thanks.
Margo
"Scott Sheppard (Autodesk)" wrote in message
news:5408686@discussion.autodesk.com...
TrueView.
Thanks.
Margo
Message 4 of 12
Hello Margot,
You can batch plot by using Publish. Go to File >> Publish.
If you need more info let me know.
Steve
Message 5 of 12
From within TrueView?
Margo
wrote in message news:5432764@discussion.autodesk.com...
Hello Margot,
Steve
Message 6 of 12
Yes Margot it's true there is a Publish in DWG TrueView.
If you have no drawing open you won't see it.
Have a drawing open. Select File >> Publish.
Works like publish in full ACAD.
Steve
P.S. Scott, If you're reading this...Publish is a feature that your customers really dislike in DWG TrueView so it's ok for you to leave it in. (heh heh heh) I'll never admit to liking it or thinking it was nice for Autodesk to put this feature in there.
With that... back to the eggnog.
Bye Steve Message was edited by: Steve Chestnut
Message 7 of 12
Thanks, Steve. I'll pass that information along.
Margo
wrote in message news:5434345@discussion.autodesk.com...
Steve
Bye Steve
Message 8 of 12
I took a look at TrueView's publish command. The problem I see is lots of
people print these files, so the last used printer might not be the printer
that the guy using publish wants to print them to. I'm wondering how hard it
would be to generate a .dsd file that tells the publish command which
printer to send all the files to. Hopefully our programmer can figure it
out. Apparently it was really easy to program something that would send a
group of dwg files to Voloview for printing.
Margo
Steve
Bye Steve
Message 9 of 12
Hello Margot,
In TrueView publish you can select a list of drawings to plot and then apply a page setup to the entire list. Experiment with the publish command. There's also good info in the Help on publish.
Good luck,
Steve
Message 10 of 12
These two articles are DWF-related but they do show info on the PUBLISH
command.
http://dwf.blogs.com/beyond_the_paper/2006/03/ggg.html
http://dwf.blogs.com/beyond_the_paper/2006/03/generating_a_bl.html
wrote in message news:5438574@discussion.autodesk.com...
Hello Margot,
Good luck,
Steve
Message 11 of 12
Scott and Steve - Thanks.
Margo
news:5438641@discussion.autodesk.com...
command.
Hello Margot,
Good luck,
Steve
Message 12 of 12
Can anyone shed some light on how to apply a page setup to the entire list. i have been trying to do this without any success.
I'm using DWG TrueView 2009 Build Version R17.2.56.0 (x86)
