DWF
Publishing Complete - Errors Found..
3 REPLIES 3
195 Views, 3 Replies
When I use Publish . add some layout to create DWF when
processing complete: errors found, save & review log file for details so i save it and check the log file it says
"Error setting plot scale and other one is
ansi expland b (11x17) layout properties error"
what gives? in plot settings is okay to HP8000 ansi b size dwg
Hope you have a solution to fix this problem
thank you
3 REPLIES 3
anyone ??? anyone?? if no one is gonna help me here
then guess I have to (edited) DWF and continue my work with
PDF.. Autodesk is pushing for DWF so hopefully someone has a solution for me thanks
My newsreader does not have the original post. So I
guess it's PDF for you.
Original post:
Subject:
Date:
Tue, 30 Sep 2003 09:08:39 -0700
ursmar
Newsgroups:
autodesk.dwf
thank you
Scott Sheppard wrote:
> My newsreader does not have the original post. So I guess it's
> PDF for you.
”Boost
”Tips
”Services
