DWF
Fit to page problem when printing DWF
7 REPLIES 7
Message 1 of 8
519 Views, 7 Replies
Just installed update to viewer the other day. Now if I print a drawing where the page size, say 22x34 is larger than the output paper size, say 11x17, and box checked for "Fit to Page" only the lower left quadrant of the drawing prints in the upper right quadrant of the paper. This worked fine before the upgrade, Any others see this? This does the same on any printer that I have.
7 REPLIES 7
Message 2 of 8
Are you printing the current view of the whole
page?
Ben
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Just
have.
Message 3 of 8
Printing the whole page. In fact I have uninstalled the viewer and reinstalled the previous version and there is no problem in printing as described.
Gil Peel
Message 4 of 8
CHriS
Excuse me! How can I programming DWF format with VBA or LISP?
Thanks.
Message 5 of 8
Have you found a solution to this problem?
I have a similar printing problem (prints were fine with Whip, but too small with EV), I bet that a fix for one would yield a fix for the other.
Message 6 of 8
I'm not sure what you are asking for.  The
fact that you mention LISP indicates you are using AutoCAD and are interested in
controlling the printing of DWF files from AutoCAD, is that
correct?
Are you trying to create DWF's from AutoCAD using
VBA/LISP?  If so, have you seen the PUBLISH command?
Are you trying to create DWF's without
AutoCAD?
Are you trying to use VBA/LISP to control the
viewing/printing of DWFs via the Autodesk Express Viewer?
Excuse
Thanks.
Message 7 of 8
Can you send Ben Cochran and I a sample DWF that
demonstrates proper printing in the old versions but not in AEV
3.1?
Thanks!
Printing
Gil Peel
Message 8 of 8
3.1?
Thanks!
Printing
Gil Peel
”Boost
”Tips
”Services
