WORK ONLINE!!!!!
WORK ONLINE!!!!!
WORK ONLINE!!!!!
I HAD ENABLED OFFLINE MODE.
now i have to go online, but i can't find "work online" option.
Mike.Grau
Hi @Anonymous,
Thank you for asking about that.
Yes, I know this is quite confusing and not really obvious.
You would just click on "Work offline" and Fusion 360 jumps back in the online mode.
I hope this helps.
i tried to click on work offline but it doesn't work.
tjstephens
There was a problem like this last weekend with the Fusion 360 service. Autodesk published a support document here: http://forums.autodesk.com/t5/design-validate-document/resolved-fusion-360-service-degradation-can-t...
If you've not got the latest version of Fusion, then perhaps you're experiencing this?
HughesTooling
@Mike.Grau There are a couple of threads like this now with no help for a couple of hours, is anyone looking for a problem?
<Mark
Mark Hughes
Owner, Hughes Tooling
Mike.Grau
Hi @Anonymous,
I got in touch with @James.Youmatz and already replied in the post here about that.
https://forums.autodesk.com/t5/design-validate-document/again-online-problem/td-p/6636941
@HughesTooling  @tjstephens
Looking at the LogFiles it looks like this is a Network related issue since the upload and save to the cloud worked several times.
Let´s keep working with James, he was able to chase down the root cause of the issue.
HughesTooling
@Mike.Grau I hadn't noticed all the posts were the same user. It's always a bit worrying when the cloud data is unavailable.
Thanks Mark
Mark Hughes
