Suggestion on how to make logo
zenkustumz
zenkustumz
Attached is a picture that i drew up and want to be able to emboss it onto parts i am designing..
I am not sure if i am using the correct wording? I want to use it like text to etch or engrave in a part.
Suggestions are welcomed. or links on how to accomplish this.
Thanks ya'll in advance
John
zenkustumz
Sorry here is attached image
Oceanconcepts
What format is your original artwork in? if it is in a bitmap format like .png the only thing you can do is to import it into Fusion as a canvas, and re-create the outline in a sketch using Fusion’s drawing tools to make closed shapes, then extrude them to make a solid you can use to cut into a part.
If your original is in a vector based format, like Illustrator, you could possibly import it as a .csv file and use the resulting sketch. However, complex .csv files don’t always import as closed shapes, and if there are a huge number of line segments it will slow down Fusion and may lead to poor results. This doesn’t look as if this would be too difficult to trace over in Fusion using spline tools, and that would probably lead to better outcomes.
There is some information on extruding and embossing here:
http://forums.autodesk.com/t5/design-validate-document/can-someone-show-me-how-to-emboss-text-on-a-r...
and here: https://www.youtube.com/watch?v=EYpDpDGdX5g
- Ron
Mostly Mac- currently M1 MacBook Pro
dual533
John,
I just did a small part of your logo using the "attached canvas" command the then sketch with the line tool mainly. (with the spline tool it seems more difficult when there are straight lines).
Have a look at the attached pictures. Hope it helps you.
Best regards
*John*
zenkustumz
thats awesome.. Thank you. now it makes scense.
Thank you very much
John
