Solved by whtank. Go to Solution.
I had tried to print to a konica minolta 350 and to cute pdf writer. In both cases nothing printed.
were you able to print?
could there have been a memory issue?
a solution would help convince the team that this is a valuable and reliable tool.
Yes, I just installed a ‘PDF Writer’ printer, test it, as a result I can print it correctly.
Could you print it correctly with smaller paper size? I can print it correctly with all kind of paper size.
I found the DWF file you supplied is composite of raster elements, there is an option called ‘Color Quality’ in the ‘Advanced Print Options’, the default value is ‘High’. Please choose the ‘Low’ option and click OK to print.
it worked!!!!
i tried multi sheets sizes and a snap shot
is the low resolution suggestioned documented somewhere? like to would find it?
thank you
When printing using ADR 2012 the application freezes in the print / nothing happens.
the original print is approx 25MB file.
