style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<Renorick> wrote in messageHas
href="news:6046727@discussion.autodesk.com">news:6046727@discussion.autodesk.com...
anyone else experienced a marked .dwf degradation of OLE objects such as an
Excel spreadsheet pasted in as the BOM? A direct plot from Autocad LT07 has
clean and crisp text in the BOM. An ADR 9.1.0.27 dwf plot made from the same
file shows text with a bad case of the jaggies, i.e. low resolution un-aliased
text. Any fix for this?
I was having the same problems when trying to print out DWF's that had excel OLE objects embedded.
My solution was very easy.
In AutoCAD plot/pagesetup, goto DWF eplot.pc3 and goto properties. Next goto Custom Properties.
Set Raster Image resolution. The higher the resolution the better the DWF. (remember to save the pc3 file or you will need to do this for all plots)
Also, I found that a super high resolution (1200dpi for me) resulted in having no Ole/picture/excel table being shown. So you need to play with the settings.
Adrian Cruz
