the problem I am having is with revit / design review mobile, I am in the process of exporting revit models to Autodesk cloud, and open the .dwf or .dwfx in mobile app design review (ipad). Everything works fine and all properties are translated from model to ipad, except for the functionality of being able to pass through or navigate through walls. The sample document provided with ipad design review is also a 3d model but allows passing through of walls, so to enter different rooms inside a building. The results I get a essentially instead of passing through the wall I continue to zoom in on the wall, not pass through.
any help, i assume this is a process durng the export, but have tried all possibilities.
