Hello helpful friends,
What I have is a tin volume surface.
I am asked to lable the points with the thickness of the volume surface.
So where there was survey data on the top layer I need to have the width of the surface at those same points.
Is anyone familiar with the commands that can make this possible? Let me know if you need more information.
Joy
Solved by Joe-Bouza. Go to Solution.
copy the points to another group and update from surface elevation and select the volume surface.
If they dont have to be the same points you can add point or surface labels by grid also
Joe Bouza
