Civil 3D Forum
view frame match line text
9 REPLIES 9
Message 1 of 10
jte9508
1818 Views, 9 Replies
I created match lines for a pipeline project through the use of view frames.  The styles I set up worked great, but I'm having a problem with the match line text.  It looks like the match line text is associated with the 'sheet number' within the sheet set manager.  The problem is that I have 4 general drawings (G1, G2, G3 and G4) at the front of my set and the first plan and profile drawing would be sheet number 5.  I don't want the match line text to show 5, I want to change it so it's associated with the 'sheet title' which is PP1.  Is this an option?
9 REPLIES 9
Message 2 of 10
in reply to: jte9508
You can make this happen in different ways.  Here are a couple:
1. Convert the field to text and change it (Edit the text, right click, convert field to text).
2. Go into the sheet set and modify the properties of the individual sheets.  (Right click on the indiviual sheets/properties).  You can give each one of them a "description" and then link the description field for your datafield in your matchline.
3.  You can give the sheet a specific title in sheet set manager, but if you want your actual sheet title in your titleblock to be different than your matchline text, this is not really good option.
These are probably the easiest, especially number 2, as you can give your sheet the full title you want, like Plan and Profile 1, but assign a description of PP1.  Then change the matcline text to call for the individual sheet set sheet descriptions.
Hope this provides some options,
Bryan
Message 3 of 10
jte9508
thanks for the response bryan.
but here's my problem.  since i created the match lines through the view frame portion of civil 3d, i was hoping to be able to "program" civil 3d to look for the sheet title instead of sheet number.  when i edit the matchline label styles in the civil 3d settings tab, when i select the text portion, on the left under the properties down arrow, i can only select the previous or next sheet number.  this then comes in as [Previous Sheet Number(CP)] in the preview.  i just didn't know if i could override that to make it look for the title.
my only other thing is to reconfigure my title block and switch the title and number fields.  i have 40 miles of pipeline in 1 alignment and do not want to reconfigure each matchline along that alignment.  so i'm trying to figure out a more elegant/efficient way through civil 3d.
i feel like i just rambled.  did any of that make sense?
-jon
Message 4 of 10
klugb
You save me from writing the description. I have the same exact problem, here is the image to go with your description.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 5 of 10
Joe-Bouza
Is this an improvement for 2009 and forward? I'm stuck on 2008 and have never been able to mix ACAD Fields with Civil3d Styles.
How do you get s Sheet set field inton your match line style?
Thanks, Joe
Joe Bouza
Message 6 of 10
jte9508
i am also using civil 3d 2008.
Message 7 of 10
klugb
I am in 2009, for now.
Not sure about 2008 but here is the way in 2009. The problem is we are limited in our choices when we get there.
Bruce
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 8 of 10
jte9508
in reply to: klugb
that's pretty much what it looks like in 2008.  and to address joe's issue, i haven't found a way (obviousy in 2008) to add in fields to any styles.
Message 9 of 10
Sorry for not responding right away- Mother Nature was kicking the door down.
I always have thought that the references to sheet set come after the fact.  Meaning, you have to manually link your text to a specific sheet set attribute.  I am not aware of being able to have datafields being inserted into styles, even if just a placeholder, which, would still be after the fact anyways.
You might be able to venture into creating a specific expression, but that is beyond my capabilities.  I would contact the guys over at http://www.civil3d.com/ (James Wedding) to see if they have found a way to utilize a specific expression for this.  Again, I think using the sheet set attributes are after the fact, but I could be wrong.
Sorry for no help and good luck!  Please post if you get a solution as sounds like this is wanted by more than one.  I use kind of the same thing, but I link mine to ssm after the fact.
Message 10 of 10
Joe-Bouza
I didn't think it was possible OOTB. However, with the help of third party stuff, if you rename renumber sheet in SSM to include your dicipline prefix your match line will reflect that. The third party stuff would need to keep track of the running sheet number. Try JTB World dot com and chris F on these boards hase some great helpers.
Joe
Joe Bouza
Rail Community
