Why do my vertical curves look different? They have same radius but the one on the right looks very strange!!!
Solved by jacob.dwyer. Go to Solution.
Solved by mathewkol. Go to Solution.
Solved by nonbeard13. Go to Solution.
In the Graphic Performance dialog try turning off High Quality Geometry and/or Smooth Line Display and see if that fixes the display.
John Mayo
hello,
look at your k values and the difference in slope between the two locations and that is why one vertical curve is longer that the other. Length is independent of the radii, length depends on the change in slopes.
nonbeard13
The one on the left I understand showing grade tangents and PVI etc same as in the pic.
But what is one on the right showing?
Any recommendation about using circular or parabolic curves? Any advantages about using one Before another? Parabolic curves give a nice K and radius values!
According to this:
Vertical curves are parabolic because it provides minimal inertial forces on the car travelling them. Learn something new every day.
