Civil 3D Forum
Use expressions for displaying slope arrows in cross section
4 REPLIES 4
535 Views, 4 Replies
I would like to label a cross section in the next way:
  If the slope greater than 1% the label appers with the real value.
  If the slope less than 1% the label disappers.
I used expression, it worked. The problem is that I cannot use this rule to the slope arrows. Does anybody know, how I can set that if the slope less than 1% not only the label, but the arrow disappear too.
Thank you.
4 REPLIES 4
troma
What is your expression for the text? You should be able to do something similar for the arrow. You may not be able to make the arrow disappear, but you can control the size of it with an expression.
Mark Green
Working on Civil 3D in Canada
doni49
in reply to: troma
I tried it Friday (using C3D 2012) and there seems to be a minimum length to the leader.  So I was ALWAYS getting a leader -- sometimes with an arrow head & sometimes.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
troma
in reply to: doni49
May have to make a custom block and use that for the arrow instead of the default. Just a shot in the dark.
Mark Green
in reply to: troma
I used the next expression:
IF(ABS{Surface Slope})>=1,ABS({Surface Slope}),-1)
If the statement is not true, the result is a negative number, and I can set that "hide negative values".
So it would be better to disappear the arrow, but if it doesn't work, I will try the reduce the size, but I'm afraid that there will appear small points instead of arrows.
Rail Community
