Civil 3D Forum
Unable to rebuild surface
5 REPLIES 5
2283 Views, 5 Replies
We are trying to convert a land desk top dwg to a civil 3d drawing and are having trouble with the surface.
When we send it to the client they get an error message that reads:
unable to rebuild surface 150thXXX
couldn't find files
w:sdskprojxxxxx150th.tin
w:sdskprojxxxxx150th.pnt
We are able to see this information on our computer but once we etransmit it, it does not take the points and surface with it.
Whats going on?
5 REPLIES 5
Can you just email them the files separately?
Bill
wrote in message news:6359347@discussion.autodesk.com...
couldn't find files
Whats going on?
We have had trouble as well. Our solution was to bring the 3d tin lines into civil and create the surface using the tin. May not be the best, but it worked for us.
When you create a Civil 3D surface from LDT the way you did, it woks great
on your machine because the TIN and PNT files are on your system...and Civil
3D NEEDS those to create the surface. When you send your client the DWG,
they don't have tose 2 extra files, thus Civil 3D has a problem.
Sending them the files as Bill suggested may work, but they would likely
need to repath them within the surface definition.
lsimm1's suggestion to import the TIN files is great since you have no extra
files to send. The DWG file will be larger, but you won't have that file
problem. Make sure, wen you're adding the TIN lines as data you KEEP edges,
or whatever it's called.
Matt Kolberg
Global CADD Systems - A division of Cansel
"tylerduncan3653" wrote in message news:6359347@discussion.autodesk.com...
> couldn't find files
> Whats going on?
Before you send the file, snapshot the surface. This will hold the
triangulation above that, including from LDD file. You then can remove
those files from the surface definition.
Matthew Anderson, PE
Hopefully, the user will not remove the snapshot and rebuild. A little
dangerous. I think I prefer the 3D lines things. Bigger file, but no
worries about removing the snapshot.
Matt Kolberg
"Matt.Anderson" wrote in message
news:6360134@discussion.autodesk.com...
>> great
>> Civil
>> extra
>> edges,
Rail Community
