Civil 3D Forum
Unable to freeze XREF'd layers
10 REPLIES 10
Message 1 of 11
7555 Views, 10 Replies
At work, we typically have "model" drawings which contain a complete layout of a project.  These are often xref'd into working drawings.
The problem is, there's often too much detail xref'd in.  I want to freeze certain layers to hide objects that aren't being detailed on that sheet, and are therefore not needed.
Here's what I'm trying:
Open the working drawing, and use refedit to begin editing the xref.
Open layer manager, and freeze or turn off the desired layers (i.e. $Layer$1, I've also tried with the setting ). At this point, the drawing looks like I'd like it to.
Save changes.  At this point, the drawing goes back to exactly as it looked before.
I'm able to make other (geometric) changes to these xrefs, just not the layer state.
Most suggestions I've found online deal with VISRETAIN, but I've tried with VISRETAIN set to 1 (as I believe it should) or also 0.
If it matters, I'm using AutoCAD Civil 3D 2013.
10 REPLIES 10
Message 2 of 11
Joe-Bouza
VISRETAIN = 1 layers changed in the xref are not reflected in the working drawing. I suggest this setting.
have you tried snowflaking the layers in the working drawing then saving the layer state?
Joe Bouza
Message 3 of 11
in reply to: Joe-Bouza
"have you tried snowflaking the layers in the working drawing then saving the layer state?"
By "working drawing" do you mean the drawing that is xref'd into the other?  To clarify - you're suggesting I freeze the layers in the original drawing, save a layer state, open the drawing with the xref, and then import the layer state?  I suppose I could try it.
Would layer names play a role here, though?  By that I mean when xref layers change to be ($Layer$1) instead of (Layer 1)
Message 4 of 11
vandenoosterkamp
You should turn off the xref layers in your masterdrawing. There is set whether the xref layer is on or off and not in the xref itself
Message 5 of 11
in reply to: vandenoosterkamp
Yes, but the problem is that certain layers need to be on/off at different times for different drawings.  One master drawing is referenced into 40+ other drawings, and each needs to have a specific combination of layers shown.
Message 6 of 11
Joe-Bouza
No, that is not what I am suggesting. If you have to have varied layer states in a drawing that contains XREFs the VISRETAIN should be 1 and the layer states controlled in the receiving drawing - not the xrefs
Joe Bouza
Message 7 of 11
Joe-Bouza
VISRETAIN = 1, layer states of receiving drawing govern
Joe Bouza
Message 8 of 11
I understand that VISRETAIN = 1 is what I want, I mentioned in my original post that I tried = 0 just because I was grasping at straws.  To be clear, you're saying that I shouldn't be editting the reference in place?  That I should freeze the layers in the receiving drawing?
Message 9 of 11
How would I go about doing that?  The referenced layers that I want off don't show up until I use refedit.
Message 10 of 11
Jeff_M
Using Refedit makes changes to the source drawing. So any changes you make will also be seen in all of the other drawings which it is referenced into. What do you mean by "they don't show up until I use refedit"? Is that in the layer manager? If so, use the Layer Filters to get them to display.
Message 11 of 11
in reply to: Jeff_M
I was under the impression I needed to refedit it while in the working drawing, but it worked beautifully this way, thank you!
Rail Community
