Civil 3D Forum
TrueView
6 REPLIES 6
272 Views, 6 Replies
TrueView
hello group
do we need any enables to be able to view civil3d w/ true view,
or wahat would be the best viewer for c3d
TIA
6 REPLIES 6
There is no enabler for True View. Whoever you get the drawing from MUST
set PROXYGRAPHICS to 1 before saving. Otherwise, you will not see any Civil
objects.
Matt Kolberg
Global CADD Systems
www.gcscorp.ca
OK, so this is an ancient thread, but I have another question relating to this. Is this a setting you have to remember to change every time for each drawing, or can you change your defaults so that every time you save, it will be proxygraphics=1?
sboon
Change the setting in your template file, so that every new drawing will have it set correctly.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Thank you! That should help us out.
AllenJessup
Help says "Configure the following settings in your drawing templates so that they apply consistently for all drawings created from the templates". Proxgraphics is first on the list.
So change it in your template file and all new drawings will have it set correctly. Existing drawings you'll have to change one at a time [or find/write some code to do it.
Allen Jessup
Allen Jessup
CAD Manager - Designer
AllenJessup
in reply to: sboon
Hi Steve. That's what happens when someone comes over to talk with you in the middle composing a reply. Half an hour later the info is already stale. Smiley Happy
Allen
Allen Jessup
Rail Community
