Civil 3D Forum
Survey Equipment Database
8 REPLIES 8
Message 1 of 9
680 Views, 8 Replies
I am currently working in C3D2009, and I am taking a shot at seeing if we can utilize the Survey functions for our data dowloads. I am trying to input the equipment information for the equipment database. We are currently using Trimble 5600 DR 200+ Total Stations, and I can't seem to match up the specs from the sheet with what C3D is asking for on the properties tab for the equipment database. Is this information really necessary for us to input in order to do a traverse analysis? Can I leave the default options and work with those? Has anyone successfully been able to add in their equipment information and it work properly? Any assistance is appreciated.
8 REPLIES 8
Message 2 of 9
bcsurvey
Going through some older threads looking for the same answers you posted here.  What did you end up doing?  I'm currently on C3D 2012 and we are getting back to making a big push to see if the equipment database is worth using.
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
Message 3 of 9
in reply to: bcsurvey
Fast forward a few years, we're now on C3D 2014 and are starting to do linework. I am trying again to see if I can find the needed information for the equipment database. If anyone knows where I can find this stuff for Topcon ES 105 - Refractive index, Wave constant, etc. - please let me know.
Message 4 of 9
rl_jackson
That information is in the Equipment Manual. However most of the settings in the default equipment database are fine.
I have however used it on an occasion where the instrument was set with a 30 degree prism and the rod was a 0 degree.
IMO they serve little purpose except for the rare instance I provided were I needed it to physically adjust the shot distance.
Rick Jackson
Survey CAD Technician VI
Message 5 of 9
in reply to: rl_jackson
Thanks for replying.
I have checked the equipment manual, but I'm having a difficult time discerning this information ( I am not very familiar with the stats for the equipment our crews use, and I can't find anything that reads the same, i.e., Nothing in the manual says "Refractive Index" or "Wave constant" specifically). We have also on occasion had to adjust a shot distance (using other software), so I want to be sure I understand how to do it with the survey tools available so we can do it all in Civil 3D (if possible).
Message 6 of 9
stacy.dunn
Before you go to the work of setting up the database, make sure that your raw data does not already have some of this information applied to it.  Some instruments will record measurement data that is already adjusted based on internal parameters.  You can also have this type of adjustment in the datacollectors, although this normally shows up in the raw data file.
Stacy Dunn
Message 7 of 9
in reply to: stacy.dunn
I'm glad you mentioned that. I checked the raw file for one of our projects, and noticed that some of this is already applied to the file. The data collectors we use do adjust the file. So the question now is this: Since the raw data I receive will already be adjusted, do I even need to worry about setting up the equipment database? Will it introduce additional error if I use it anyway? Am I able to work with the raw data without using an equipment database?
Sorry for all the questions - I'm just trying to figure this out. Any advice is appreciated.
Message 8 of 9
rl_jackson
I would just except the defaults. I have never had a single issue, and that goes all the way back to LDD that there has been an equipment database.
You can however use it to covert thing, like I mention regarding the prism. It will also convert a fbk file that was done completely in metric to feet if necessary.
It really depends on the situation (field flub up) that happens and believe you me it does and will happen.
Rick Jackson
Message 9 of 9
Ok. I'll keep the defaults and go from there. Thanks.
Rail Community
