Civil 3D Forum
Surface contour issues
2 REPLIES 2
309 Views, 2 Replies
I am having some issues with my surfaces and I would appreciate some help.  I used Civil 3D's grading tools to grade a small subdivision.  Then, I extracted the contours, which made them polylines, and did some hand drafting on the contour lines to clean up the drawing.  I then created a new surface and added the polylines to this new surface as contours.  When I turn on the layer controls for my contour layers in this new surface, the layer controls in my other surfaces turn on as well.  I do not want to see the contours from the other surfaces.  What is going on and how do I correct it?
2 REPLIES 2
troma
What is going on is that you have two surfaces on the same style. Edit the style, and you are editing what all surfaces on that style will look like.
Copy the surface style, or make a new one for yourself.
http://docs.autodesk.com/CIV3D/2013/ENU/filesCBP/GUID-D75B10D6-B16D-4131-823D-F10B5BDA14D1.htm
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/empty_concept_483.htm
While you're at it, please note that using contours to build a surface is one of the worst ways to go about it. Your method may make a great looking surface in plan, but not in profile or in 3D. If you change your contour interval you will see messes in plan too. However, if you are left with no option but this workflow, please read http://civil3dplus.wordpress.com/2011/08/13/adding-contours-to-a-surface-youre-doing-it-wrong/
Mark Green
Working on Civil 3D in Canada
in reply to: troma
Or keep your polylines for the file and label them up. use the surface with a no display if you need to get quantities or grade to it. You have already removed yourself 1 step from the grading objects so using the plines for final grade representation at this point is not the end of the world.
my 2 cents for what it is worth (hopefully at least 2 cents LOL)
Rail Community
