Civil 3D Forum
Set Pipe Network Part Catalog via LISP
5 REPLIES 5
852 Views, 5 Replies
Does anyone know of a way to set the pipe network catalog path using a LISP routine or other script file?  We switch between catalogs quite often.  It is time consuming to browse folders.
5 REPLIES 5
rkmcswain
I was hoping for this also.
I suspect you could brute-force it since there doesn't appear to be a command line version of the command "SetNetworkCatalog".
Set the desired settings, export this key, and repeat for each set of settings.
Then import the .REG file as needed.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-Dxxx:xxx\Profiles\<<Profile_Name>>\Preferences\AeccUiNetwork100
R.K. McSwain     | CADpanacea | on twitter
rkmcswain
in reply to: rkmcswain
Thanks.  That looks promising.  I posted that question two year ago and had forgotten about.  However if the solution in the newer post you linked to works that would certainly be valuable.
rkmcswain
I also just added the "wish" in the C3D Ideastation too.
rkmcswain
For now -- I think I'm going to go with the REG file and import it at machine startup/login via group policy. The fewer things AutoCAD has to do at startup, the better....
Rail Community
