Hi all,
I don't often work with cross sections so I am having to build the company template. The automatic elevation datum seem a little conservative and is leaving a decent amount of sheet space under each cross section. It is possible to have any control on how Civil 3D automatically assigns a datum to a cross section? I don't want to manually assign an elevation to each cross section, there are too many sections and the elevation varies too much for this to be practical.
Mike Kingdon
Civil 3D Zealot
Solved by ecfernandez. Go to Solution.
Hi @m_kingdon, this AU Class might help you
Link: Stack Your Sections: Tips for Building Section Sheets Efficiently
Regards!
