Civil 3D Forum
Section View Labels
2 REPLIES 2
SMHConsultants
280 Views, 2 Replies
Section View Labels
I can't seem to add section view labels in Civ3D 2011. I follow the usual procedure, but after I pick a point in the section view nothing happens, all it does is continue to ask for another pick point. Has anyone else had this issue? and more importantly the solution.
2 REPLIES 2
Have you check the layers are on that section view labels are going to?
Have you check the label style you are using has the label components turned on?
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Are you getting a prompt to pick a second point or you are still at the first point? If it's going to help, this is how it works on my machine: http://screencast.com/t/xyofqhPvmGW
Do you have another dialog opened somewhere?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
