Civil 3D Forum
Screen flashes during Save
7 REPLIES 7
Message 1 of 8
rkmcswain
558 Views, 7 Replies
I have a drawing that when I am in a layout and run QSAVE (or if autosave fires), the screen "flashes". More specifically the layout disappears for a second and during this time, the entire screen is black (the animated GIF below plays a bit fast)
This only happens in one particular drawing, and any drawing this one is xrefed into. Before I recreate this drawing from scratch, has anyone else ever seen this?
EDIT: If I turn off REGENAUTO, the flash does not happen. Still, something is weird about this drawing.
R.K. McSwain     | CADpanacea | on twitter
7 REPLIES 7
Message 2 of 8
jmayo-EE
in reply to: rkmcswain
Oh you get some great stuff. I have never seen that. Did you confirm the issue on another PC?
John Mayo
Message 3 of 8
troma
I sometimes have a black screen during regen. If you run REGENALL without the QSAVE do you get the flash?
Mark Green
Working on Civil 3D in Canada
Message 4 of 8
rkmcswain
in reply to: troma
John, yes it does the same thing on other machines.
No flashing during a regenall. Only during Qsave and autosave with Regenauto enabled.
And to add to the mystery... if I switch to MS from the layout and run a QSAVE, about 1/2 the time the drawing will do something funky like pan or zoom on its own during the save (instead of the flash I get in PS). I hate the unknown. It's probably nothing but an annoyance, but I would hate to ignore it and then start running into corrupt drawings in a few weeks...
Message 5 of 8
jmayo-EE
I would be worried about that one too. I would use a Selectall and go through the props to see if some unexpected objects are in the list. I think I would also try to xml and wblock it into a new dwg hoping to resolve the issue. Perhaps in pieces to help identify what is giving you the light show.
John Mayo
Message 6 of 8
rkmcswain
in reply to: jmayo-EE
Yep, done everything along those lines that I can think of....
I did manage to catch it doing the crazy pan (and pan back) in MS during a save. (once again, the GIF plays faster than real speed)
Message 7 of 8
jmayo-EE
Ok I'm curious with this one Randy. Any luck rebuilding the lots from xml or blocking? Still have the light show?
John Mayo
Message 8 of 8
mkcarchitect
I'm having the same problem with one drawing.  All other dwgs are fine.  I hope we can figure this out!!
Rail Community
