Is there any way to rotate and mirror an objcet while leaving the original.
eg. I have half a window like so
A _____________
| B
I want to mirror along point A and B so the bottom and left side of the window is shown.
Solved by Neilw_05. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
AW,
I don't think you can do this in one move. Copy, then rotate, looks like the best option.
Dave
Dave Stoll
Las Vegas, Nevada
Express>> copy move rotate does all in one command line sequence. If I recall correctly
http://www.adris.co.uk/architectural-tips-tricks/94-issue-001-movecopyrotate-mocoro
Joe Bouza
Joe,
I learn something everyday. That MOveCOpyROtate command is brilliant! Good link, too. Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Hi Dave
I'm sure you are aware of the contextual right click menu containing the fundemental geometric modifying command while hot gripped.They are all there
Joe Bouza
Actually I think the Align command is more appropriate than Transform. If you pick the destination points in reverse of the source points it will mirror.
Screen recording: http://screencast.com/t/oSfGmoyjGYTA
Thank you all so much for your help.
The Align command is great, the only problem is that it dosen't leave the original line(s) behind so I have to copy with base point and paste on top of original line(s) or somewhere near and then perform the align.
I don't know where I'd be without you guys.
But is very close to what I wanted, so thank you. I think this is as close as I will get.
