Argh!!!!!!
It doesn't matter where you set the Next Point Idenity
In the Create Points dialog Box or The Command Settings
Choose Create Points Interpolate and it resets to the lowest point number avaliable.
Or.....
Renumber some points that got entered wrong (From above problem)
now try to create a point manualy
the numbers already exist so instead of renumbering automaticly all you get is NOTHING!!!
You have to reset the next point number. And if you enter a number that exist all it tells you is
"Point Number Must be Unique"
AUTODESK FIX THIS PLEASE!!!!!
As if there aren't enough time wasters built in ๐
Did you submit this to Autodesk support?
