I'm trying to pick a specific design profile as a reference profile in pipe run profile settings to make the pipe run follow this design profile but it shows only few profiles how can I show all profiles in the drawings.
Hint: I have seen on my friend's pc a different look for this settings i think as attached.. what make this difference and how can i change from one to another.
Notice: it has nothing to do with the version i have both civil 3d 2021, 2022, 2023 and 2024 they are all the same and my friend's pc has civil 3d 2021.
Thanks.
I haven't had much luck using the "new" pipe run system for pressure networks. Like you, I wasn't able to make a pipe follow a profile that I created as it won't list it. I tried just using the one it creates and editing that, but then I ran into the idiotic problem that you cannot have a 90 deg vertical bend in a pipe run, which makes the pipe run system mostly useless.
If you ever figure out a way to get a user created profile to show up in that list, I'd like to hear about it.
It's not about a specific drawing it shows like this for all drawings i think its about the civil 3d version or some settings that need to be adjusted.
