Civil 3D Forum
pipe network structure label
9 REPLIES 9
Message 1 of 10
CADmgrMike
824 Views, 9 Replies
We have a block that we use for an eccentric manhole that shows the lid offset. (see pic)
I would like to create a label that displays the rotation of the structure with N,S,E,W like you can with the pipe direction field.
Has anyone ever tried this?
Mike Porter
https://provostandpritchard.com/
9 REPLIES 9
Message 2 of 10
in reply to: CADmgrMike
There is a Structure Rotation Angle option for Structure labels.
Message 3 of 10
CADmgrMike
Yes, I have played around with that field a bit, but haven't gotten it to display the data as N,S,E,W.
Mike Porter
Message 4 of 10
You could create an Expression to convert this field to return a Direction. However, you will still have a number to deal with.
Message 5 of 10
CADmgrMike
I like your idea.
Not sure what you mean by having a number to deal with?
I"ll give it a try and see what I can do.
Thanks.
Mike Porter
Message 6 of 10
Bill_Myron
Expressions cannot return strings. Such as N, S, E, W.
There is a terrible workaround though.
Create 4 expressions (8 if you want NW, NE, SW, SE). These will be if statments.
If the the rotation of the structure falls within the Dierection range
=IF(AND(Structure Rotation>XX,YY>Structure Rotation),(Whatever your text hieght is),0.00001)
Make however many of those you need for each direction. In your label add a text component for each direction. Place them all in the same place on top of each other. Apply the coresponding expression to each text.
Now when you rotate your structure it will only display the correct direction. All the other directions will be sooo small you wont even notice them.
Hope this makes sense!
Message 7 of 10
Joe-Bouza
Hi Bill
Not sure I follow the "And" in your code. Could you elaborate ?
Joe Bouza
Message 8 of 10
Here is a thread discussing this same concept Bill is referring to. http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/text-in-style-expression/td-p/2893280
Message 9 of 10
It think this drawing has a better example of what you want: http://style.civil3dreminders.com/structurelabel-pipedirection
Message 10 of 10
Bill_Myron
in reply to: Joe-Bouza
So I may ahve spoke too soon about the and, apparently it is not included with Civil 3D. BUT, there is a way to get this done still. There are other ways to get an "AND" in the expression to get the range.
From the help on on expressions under operators:
Logical operators return 1.0 for true and 0.0 for false. Since they return values, you can perform logical AND and OR with addition and multiplication. For example: ((a<b) + (b>c)) tests for a < b or b > c. ((a<b)*(b>c)) tests for a<b and b>c.
So if we apply these in our IF statement we will get the desired result.
Our North is 90 so these are written for that direction. If your directions are different, adjust accordingly.
Ranges:
East - 315 to 45
North - 45 to 135
West - 135 to 225
South - 225 to 315
Expression:
IF(({Structure Rotation Angle}>DEG2RAD(135))*({Structure Rotation Angle}<DEG2RAD(225)),TEXT HEIGHT,0.000001)
This tests if the angle is greater thatn 135 AND less than 225.
For the range that crosses th 0 degree you will ahve to change the "AND" to an "OR".
IF(({Structure Rotation Angle}>DEG2RAD(315))+({Structure Rotation Angle}<DEG2RAD(45)),TEXT HEIGHT,0.000001)
Each direction will need its own text component and expression.
I made a quick label in a drawing and attatched it.
Rail Community
