Hello, I am creating a corridor for a road that consists of one alignment and a design profile. I initially created the corridor from beginning to end using the same assembly and then went back to identify station ranges to insert regions that will transition my daylight slopes.
Is it possible to have an assembly for the left side of the road and an assembly for the right side of the road and create regions that overlap station ranges? I have a left daylight transition and a right daylight transition happening in the same location but the left slightly sooner than the right. I'd like to use left lane and right lane assemblies to create overlapping regions. For example, I have a left lane transition region from station 1000 to 1050 and a right lane transition region from station 1025 to 1075 for the different daylight transitions happening on opposite sides. Is this possible?
Solved by Jowennl. Go to Solution.
Hi @demus72,
This is doable as what you describe. First make your corridor using left side assembly, say align mc10 and profile mc10. Then in the same corridor click add new baseline and pick the same alignment mc10 and profile mc10. Select the new baseline and add region and use your right side assembly. You can have as many baseline you want and can even pick other alignment and other assembly.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
