Does anyone know how to get this dialog back? (see attached image) I like it to pop up as a warning when users open up a Land Desktop drawing in Civil 3D, but when they click on "Do not show..." I can't figure out how to get it back. I've searched all over in the help files, Google, looked in the registry, everything I can think of. (Also, PROXYNOTICE is already set to 1)
Solved by AlmasSuljevic. Go to Solution.
Ji Justin,
Type AECFILEOPENMESSAGE in command line and set it to YES. This shoud work.
Similarly, you can add:
(command "AECFILEOPENMESSAGE" "N")
to any 'startup' settings file you may run (ACADDOC.lsp, etc)
