Hello
I am running AutoCAD Civil 2015, when i run a Map command, for example Define Object Data (adedefdata), i do not get a window to make my selection/edits, i get a compand line promt, similar to if i had FILEDIA set to 0. It is set to 1 and all my Civil and Regular CAD tools (that have pop out windows) come up normally. I have not been able to find a system variable that only controls the Map windows, is there one? or does anyone have an idea what may be causing this?
Solved by AllenJessup. Go to Solution.
Glad it helped. Check your Preferences at the top of the page. On the Preferences tab select Notification Settings.
Allen
Allen Jessup
CAD Manager - Designer
