I've started compiling a list of Map 3D commands that appear in the Civil 3D help files and Autocomplete list that either don't work or function differently than described in the help file.
I've attached a file that contains what I have so far. I know it's probably no where near complete. I'd welcome any contributions from those who have encountered commands like this.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Allan,
Make sure you are using the default pgp file. There are 5 commands that have been redefined in Civil 3D to use that version of the command instead of the Map 3D version
MAPCGADIST, *AeccCgADist
MAPCGANG , *AeccCgAng
MAPCGCDIST , *AeccCgCDist
MAPCGLIST , *AeccCgList
MAPCGSLIST , *AeccCgSList
Peter Funk
Thanks Peter. I'll look in to that. I had thought I had started with the latest. But I may have grabbed the wrong one.
Allen
Allen Jessup
@vcoleman wrote:
try setting demandload to 3
I believe it is or if not it's only been since Friday. I'll check it as soon as I get a chance.
Allen
Allen Jessup
Peter, I found the correct PGP file. There are a lot that ship with IDSP and I must have grabbed the wrong one. I always create a custom one on our server and missed this with 2014.
Thank you.
Allen
Allen Jessup
I confirmed that demandload is set to 3.
After adding the aliases that Peter mentioned. Those commands are mapped to the equivalent Civil 3D commands. The commands now "work" because they call non-Map commands. The others still return Unknown Command.
I'm not trying to MAKE the commands work. I'm looking to compile a list so that when someone posts SuchandSuch Map command doesn't work. I can provide the list to them so they can tell what commands have been disabled.
I've only come across one AutoCAD command, Partial Load, that doesn't work in Civil 3D. If I find others I may start a list of them.
Allen
Allen
Allen Jessup
