Civil 3D Forum
Major contours round up?
3 REPLIES 3
Brin33
840 Views, 3 Replies
Hi all,
When I try and display contours with the standard surface style Contours 0.1m and 0.5m It rounds up the major 0.5m contour.
I thought I had found the precision and rounding settings, but when I change them to precision of 0.1 (Or whatever) there is no change to the contour lables dispalyed.
I am changing the values in the Toolspace settings tab, Surface>Label Styles>Contours>Major
component name >Surface Contour Level, Then clicking in the Text Contents Value.
Properties>surface Level... then finally the precision and rounding values are here.
Is this the correct place to make changes?
If so, what could I be doing wrong? I cant see any overrides, or any other areas to change the precision for these major contours. (I checked the precision on the other contour styles as well, in case I was using a diffrent one by mistake.
Brin
3 REPLIES 3
neilyj666
in reply to: Brin33
You are in the correct place - see screenshot...
You need to select the text (in blue on screenshot) and delete, then set the precision (1 in the screenshot) then hit the Right Arrow (yellow box highlight) to transfer the setting, Ok out and that should sort it....
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Brin33
in reply to: neilyj666
Excellent, Thanks for the reply.
So many options to keep up with!
neilyj666
in reply to: Brin33
Glad it's sorted out - the click on the right facing arrow isn't the most obvious action and still catches me out occasionally
Rail Community
