Civil 3D Forum
Lines show up as foggy grey but don't have that property
10 REPLIES 10
Message 1 of 11
featho
2979 Views, 10 Replies
The above sums it all up. Note the properties are NOT GREY they are what they are supposed to be.
The file was created in version 2012 by another designer now it is being completed in 2013 by myself.
I can do a quick fix by creating a wblock of the problem lines and text etc to enable a print out without the GREYING
problem but once the drawing is closed and opened once again the drawing has GREYED whatever is in model space again.  (note that xrefed lines etc are fine)
Please help me fix this.
Regards
Carla Featherstone
Ps I have attached the problem file with all the xrefs and jaz unattached/taken off etc
10 REPLIES 10
Message 2 of 11
Joe-Bouza
in reply to: featho
dumb question but I'll ask it.
I dont have cad handy but in the plot settings is "display plot styles" checked?
Joe Bouza
Message 3 of 11
Jeff_M
in reply to: featho
I don't know what causes this, or how to correct it, but the 2d Wireframe Visual Style is messed up. Chnage to any other visual style and the linework shows correctly, change it back the the 2d wireframe and it gets hosed. You can work around it by inserting the drawing into a new drawing, then use Design Center to bring in the layouts.
Message 4 of 11
featho
in reply to: Joe-Bouza
No it isn't checked
Edited by
Discussion_Admin
Message 5 of 11
featho
in reply to: Jeff_M
Thanks Jeff I'm pretty sure that inserting into another drawing doesn't work too. That was interesting about the wireframe. Not sure what to do still Thanks for your time Carla
Edited by
Discussion_Admin
Message 6 of 11
Jeff_M
in reply to: featho
Carla, I tested the inserting to another drawing, using your drawing, and did work for me. Perhaps your template has the same issue? Could you try with a different dwt?
Message 7 of 11
featho
in reply to: Jeff_M
So you inserted a wblock into another drawing? Is that right? I will give that a go now to check it Talk soon
Edited by
Discussion_Admin
Message 8 of 11
Jeff_M
in reply to: featho
I just started a new drawing, then used INSERT to insert your entire drawing into the new one.
Message 9 of 11
in reply to: featho
I just read this post about an hour ago:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/text-and-line-work-in-model-space-turns-gray-when-I-r...
Sound about the same to me.
Message 10 of 11
Jeff_M
Sure enough. It's late Friday afternoon and I can say I learned something today! Smiley Happy
Message 11 of 11
featho
in reply to: Jeff_M
I checked out the old post and this worked for me too YAY Thanks HEAPS for that 🙂 FEATHO
Rail Community
