Sorry to revive an old thread, but in case anyone is trying to remove the Legend textstyle, these are the steps you can take to do so:
The tablestyle 'Legend' is what Map 3d uses when creating a Map legend. It seems Map is hard-coded to use 'Legend', because even when it is removed, if you use Map's "Create Legend" command, it recreates the 'Legend' tablestyle.
We don't ever use Map, and it feels really good to start with a clean template, finally.
