Civil 3D Forum
labeling cross sections where you can't change the link codes
1 REPLY 1
192 Views, 1 Reply
I am having some trouble labeling a few slopes in my cross sections.  My problem is with the links that use only "Top" and "Datum" link codes and I don't have an option to add any more.  I don't want to turn either of these link labels on because then my cross section will have an overwhelming amount of labels.  In some subassemblies I can add a Link Code and make sure the code is on in my Code Set Styles, however there are some where this is not possible and those links are the ones that I want labeled.
Does anyone know how I can label these slopes of the links that just have the codes of "Top" and "Datum"
Thanks!
1 REPLY 1
mathewkol
You could add a dummy link over top of the one you can't change and rename that one.
Which SA are you using that can't be changed?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
