I created label style to get distance between two alignments (see picture).
The label is type "main station" (see picture). In the expressions don't appear the property "offset".
How do I center the label between the two alignments?
Solved by ChrisRS. Go to Solution.
More information would be useful.
What is the expression formula?
Can you provide a sample drawing?
Christopher Stevens
I didn't use expressions.
The style is called "interasse" and is type "main station" (see picture). In the definition of style I have create the component "text reference" and used property "offset".
I need to use an expression in cell "Y" to center label between the two alignments.
I attach the file civil.
Thank you for the drawing.
You are correct that the reference text does not have expressions available.
Sorry, I do not know a workaround. You might look into Dynamo.
Christopher Stevens
I would like to try in Dynamo, but unfortunately I don't know how it works 😞
