Civil 3D Forum
Label style "alignment distance"
4 REPLIES 4
dar.lombardi
215 Views, 4 Replies
I created label style to get distance between two alignments (see picture).
The label is type "main station" (see picture). In the expressions don't appear the property "offset".
How do I center the label between the two alignments?
Labels (1)
4 REPLIES 4
ChrisRS
in reply to: dar.lombardi
More information would be useful.
What is the expression formula?
Can you provide a sample drawing?
Christopher Stevens
dar.lombardi
in reply to: ChrisRS
I didn't use expressions.
The style is called "interasse" and is type "main station" (see picture). In the definition of style I have create the component "text reference" and used property "offset".
I need to use an expression in cell "Y" to center label between the two alignments.
I attach the file civil.
ChrisRS
Thank you for the drawing.
You are correct that the reference text does not have expressions available.
Sorry, I do not know a workaround. You might look into Dynamo.
Christopher Stevens
dar.lombardi
I would like to try in Dynamo, but unfortunately I don't know how it works 😞
Rail Community
