I know I can use "<[Geometry Point Entity Before Data(CP)]>" (or after...) .
But this text is tooooooooo long.
Is there any way to get only the :
- radius - length of segment. or - Spiral A ???
Any hidden trick ? Maybe using expressions? In this case any hidden elements? ANY TRICK ?????
I know I can use segments or multiple segments but I want to do the work in only 1 labeling step ...
Thanks.....
Not with 1 labeling step. You'll have to use 2.
Peter Funk
So then .... please think on users.......
Program this please :
"Geometry Point Entity Radius or Spiral A Before Data"
"Geometry Point Entity Lenght Before Data "
(I dont understand the reason to join all the information on "Geometry Point Entity Before-After Data". Is that you have never seen the big clutter you have if use it ?) ..... Oh my god....
Thanks any way.
In Drawing settings, in the Abbreviations tab you can change what will be written.
Line end, Line beginning, Curve end, Curve beginning, Alignment beginning point and so on.
Delete the text you dont want, and keep R=<[Radius(Um|P3|RN|AP|Sn|OF)]> and A=<[A(Um|P3|RN|AP|Sn|OF)]>
/Camilla
