Civil 3D Forum
Identifying areas of widening
40 REPLIES 40
Message 1 of 41
neilyj666
1490 Views, 40 Replies
I'm working on a windfarm access road (5m wide with widening at bends to 8m) and I need to identify the areas of widening.
I've got the centreline alignment and created the 2.5m offsets to each side. I have also created widenings on the insides of the bends using the widening tools and used a linear taper at entry and exit. I now need to hatch up the portions where the road has been widened to demonstrate compliance with the specification and the only easy way I can see is to export to autocad and use the hatch tools (not tried to hatch between alignments).
Whilst this works it isn't dynamic so if the alignment is adjusted the widening alignments are also moved but the hatching remains.
is there an easier way to do this?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
40 REPLIES 40
Message 2 of 41
fcernst
in reply to: neilyj666
Yes, with Link Codes.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 3 of 41
Joe-Bouza
in reply to: fcernst
Ditto. I just did that.
http://docs.autodesk.com/CIVIL/2010/ENU/AutoCAD%20Civil%202010%20User%20Documentation/index.html?url...
Joe Bouza
Message 4 of 41
neilyj666
although as I don't have this modelled as a corridor I don't think this is the way forward.
I also can't see how this could be achieved even if I did have a corridow
Message 5 of 41
fcernst
Yes, this is definitely the way to go. It is super easy... and dynamic per your request.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 6 of 41
neilyj666
I can't see how the widening portion would be identified?
Message 7 of 41
fcernst
Send me your drawing and I will demonstrate this to you.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 8 of 41
neilyj666
ok will send on Monday
Message 9 of 41
neilyj666
XML of alignments - screenshot (done via hatching in ACAD drawing) shows what I want to show dynamically
Message 10 of 41
fcernst
The XML didn't preserve the C3D smart Offset relationships with the CL alignment.
I just quickly created a CL with constant 12' wide paved lanes either side of CL, then did some exaggerated Widenings (magenta hatch) for demonstration purposes.
This is all dynamically reponsive to changes in the Parent Alignment.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 41
Lisa_Pohlmeyer
I use the process that Joe linked to all the time to show the difference between existing & proposed for our corridors. We often have alignment modifications, our existing uses a different code for the pavement link than the proposed, same result.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 12 of 41
neilyj666
in reply to: Lisa_Pohlmeyer
Thanks to Lisa and fcernst for the replies - these methods rely on having a corridor modelled i.e. assembly, profile and horizontal alignment do they not?
I only have a horizontal alignment...
Message 13 of 41
Joe-Bouza
Yes we are talking about corridors.
Joe Bouza
Message 14 of 41
If you only have alignments, add another set of widenings that to the normal road width and then hatch between those and the ones with the widenings. You might need to turn off the labels before you do that. If you use this or the corridor method you should end up with widenings and hatches that respond to changes in the design.
Peter Funk
Peter Funk
Message 15 of 41
fcernst
That's fine. That's all I started with...
Hint for homework: I did not have to use any surfaces, neither for a Profile or Targets...
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 16 of 41
Joe-Bouza
I concur with Fred. You do not have to model the corridor to utilize the code set abilty to hatch
Joe Bouza
Message 17 of 41
fcernst
in reply to: peterfunkautodesk
Peter,
I just tested your suggestion and the Hatch disappeared when I moved the Parent Alignment.
Is that a defect?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 18 of 41
fcernst
This is not stable. Now it is staying in the Drawing, but losing its Associativity.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 19 of 41
This doesn't seem to work - I created two more offset alignments with the standard offset and hatched the relevant areas. I then dragged a parent alignment about 5 minutes ago, the alignments moved but the hatch remained and C3D has gone into "....Not Responding..." mode
Message 20 of 41
Joe-Bouza
The corridor is easy and does not have to model and is dynamic.
rename the file with dwg extension; the dg wouldn't let me post a drawing for some reason
Joe Bouza
Rail Community
