Civil 3D Forum
How can I put a dashed underline under mtext? or regular text?
20 REPLIES 20
Message 1 of 21
tworzella
2615 Views, 20 Replies
Our CSM drawings require dashed lines under certain text, but just drawing a line under it is proving problem some when using in different annotative scale pages.
Todd
20 REPLIES 20
Message 2 of 21
johngordon6189
in reply to: tworzella
You would have to draw the line and adjust the linetype scale of the line to accommodate the scale of the sheet.
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 3 of 21
tworzella
in reply to: johngordon6189
Yes, but the line stays the same length as the text gets bigger or smaller with the scale changes.
Thank you,
Todd Worzella
Todd Worzella - Senior CADD Technician/IT Support
[ToddWorzellaBC]
Connect with us: [LinkedIn] [Facebook] [gplus-28]
Confidentiality Notice: This message is intended for the recipient only. If you have received this e-mail in error please disregard.
Message 4 of 21
johngordon6189
Yes, you would have to adjust the length of the line to suit the scale. That's the only way I know of putting a dashed underline upon text.
John Gordon
C3D 2018/2020
Microstation
Windows 10
Message 5 of 21
If your CAD standards allow you to use PSLTSCALE = 1, do it! This makes linetypes draw the same at all annotation scales. Unfortunately, if you aren't consisitently using LTSCALE = 1, you will run into problems as it is a drawing wide setting.
Message 6 of 21
Joe-Bouza
Just a stab in the dark: Perhaps an annotative multileader defined with a block of the dashed line attached to the landing might work. Or a annotative dyno block with a multiline attribute.
Joe Bouza
Message 7 of 21
vlsheehan
in reply to: Joe-Bouza
How about an annotative block with attributes or maybe a dynamic block?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 8 of 21
tworzella
in reply to: vlsheehan
Can you get the dashed underline to automatically adjust to the length of the text?
Message 9 of 21
SkipBurns
You could use a Civil 3D Note Label.
Message 10 of 21
Joe-Bouza
Hi Vincent
Whats your question?
Joe Bouza
Message 11 of 21
vlsheehan
No question really. I'm thinking this can be done with an annotative block with attributes or maybe a dynamic block.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 12 of 21
Joe-Bouza
Me too. maybe you didn't realize you responded to my post suggesting the same 🙂
Joe Bouza
Message 13 of 21
doni49
That would still require manually changing the line length to match the attribute (text) width which the OP has already said he's looking to avoid.
I *think* that an add-in could be written to do it.  But it would require a lot of background overhead and I would question its value.
This add-in would have to get loaded with EVERY dwg file.  Then it would register an event handler so that everytime this block's attributes are changed, the add-in would get the new attribute length and change the line length accordingly.
But as I said, I would question its value vs all that added overhead.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 14 of 21
Joe-Bouza
in reply to: doni49
Hi Doni
The idea behind a dyno block is that it maintains the same plotted size regardless of scale. As you can see in the image the visual fidelity for 10, 20, 50, 100 and 200 scale the block resizes as would the anno attribute that would go on top of it. There would be no need to manually resize the line, as you can see. The op would however have to manually adjust the postion based on scale but that comes with the territory of using annotative annything. And yes, with a little more thought the ltscale can be cotroled too
Joe Bouza
Message 15 of 21
doni49
Ooooohhhh -- I'm gonna have to investigate these.  I thought you were referring to Dynamic Blocks and I had previously tried to something very similar to this using Dynamic blocks (last year when I first got started using them) and when I asked about it, the consensus was that it couldn't be done.
Don Ireland
Message 16 of 21
SkipBurns
I still think a Civil 3D Note Label would be the best bet.  The line can be attached to the text and will always be correct.  See attached image.
Message 17 of 21
Joe-Bouza
in reply to: SkipBurns
I see your point Skip, but the lack of visual fidelity makes it problematic at multiple scales; i.e. various positioning suitable for specific scales
Joe Bouza
Message 18 of 21
tworzella
That works , but they want it to be able to do multiple lines of text.
Message 19 of 21
Joe-Bouza
in reply to: doni49
and here it is with the attribute
Joe Bouza
Message 20 of 21
doni49
Joe,
Would you mind posting that block?  I'd to experiment with it.
Don Ireland
Rail Community
