hi,
I've attached a high quality TIF (688MB) using 'Connect' > 'add raster image or surface'>'connect'> 'add to map' and the image is blurry when zoomed in, in both model space and in viewports that are zoomed in. How can i get civil 3d to use the full resolution of this tif?
It shows up in the correct location under contours made from a point cloud file, it's just nowhere near its regular resolution that it has when it's viewed as a tif file without autocad.
I cannot find a working solution anywhere and I believe that I am likely missing something simple. Thank you!
Tim
Solved by doben. Go to Solution.
Does it also plot blurry?
There is a setting "imagequality" . Maybe yours is set to draft?
The setting only affects what you see on screen, not the plot quality.
How about if you insert it using Mapiinsert.
Tim, glad to hear it worked.
I usually use the mapiinsert method as it gives more control; clipping, fading. (unless there's ways I'm not aware of with the "connection" method). I've never noticed an improvement with performance either with the connection method.
Don
