Civil 3D Forum
Extract and export surface contours and labels
17 REPLIES 17
Message 1 of 18
20869 Views, 17 Replies
I want to extract contours with elevation labels from a C3D 2011 surface for use in another 2011 drawing without the surface, as polylines and labels.  Is there a way to do this?
17 REPLIES 17
Message 2 of 18
annw2
You can explode a surface twice to get poly lines at elevations.
I don't know what happens to the labels.
Probably need to re label in LDD.
Ann Wingert, P.E.
Message 3 of 18
You can do the same with the labels explode the labels and they become text
Message 4 of 18
AlmasSuljevic
Just to add my 2 pennies. I think you can go about it without ruining your surface by explode. If you select your surface and go Extract Objects you will be able to get contours as polylines. See image:
Labels you would need to explode. Good luck.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 5 of 18
Joe-Bouza
in reply to: AlmasSuljevic
Explode what a violent wat to resolve an issue.......... wait a minutes? mankind has been doing that since the discovery of gun powderSmiley Surprised
Joe Bouza
Message 6 of 18
AlmasSuljevic
in reply to: Joe-Bouza
Just gave you my kudos for your last sentence.
Almas Suljevic
Message 7 of 18
Adam_Farnsworth
There is something exhilarating about using the explode command.  I sometimes even make a little explosion sound as I press enter (usually on stressful days lol) Smiley Wink
--Adam
Windows 7 x 64
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Message 8 of 18
Joe-Bouza
There is some truth to social conditionig. Smiley Wink
Joe Bouza
Message 9 of 18
Joe-Bouza
in reply to: Adam_Farnsworth
It would be fun if you could add some type of script to a button that would trigger a windows sound of an explosion Smiley Wink
Joe Bouza
Message 10 of 18
annw2
Can you tell it is Friday?  Back at office on old computer which works for forum.
Do a SAVEAS to create a copy of your file before expoding or save just before exploding & WBLOCK out contours then quit drawing without saving to preserve model.
Does that Explorer 9 glitch that causes blank posts also cause reply to wrong post in this forum?  I've seen this forum do lots of weird things when I try to reply.  Will have to check reaction old to new computer.  We upgrade to get worse performance why?
Ann Wingert, P.E.
Message 11 of 18
Murph_Map
Refine your explode command and add this
defun Bang (str)
  (vl-load-com)
  (setq sapi (vlax-create-object "Sapi.SpVoice"))
  (vlax-invoke sapi "Speak" str 0)
  (vlax-release-object sapi)
(Bang  "BANG ")
Murph
Supporting the troops daily.
Message 12 of 18
I tried extracting the contours, but it does not accomplish what I need. I use Civil 3D 2013 and I sent my drawing (with surface contours) to someone using Carlson 2013. My contours were not visible. When I extracted them and sent it they could not open the drawing at all. I had to completely explode the surface and then I lost my labels. Even though the resultant polylines maintained their elevation, I was unable to label the polys with elevations.
Message 13 of 18
jmayo-EE
Did you try using the Export To AutoCAD commands? This may be the best way to send the surface.
John Mayo
Message 14 of 18
in reply to: jmayo-EE
I think maybe exporting the surface to an XML file might be the way to go. I tested it with Microstation, and it was successful.
Message 15 of 18
I did not know I could do that. I am going to test it. Thanks!
Message 16 of 18
It worked! Thanks so much. I didn't lose the contour elevation labels either.
Message 17 of 18
dilsmails1
sir when i am exporting the contours, it becomes exploded as single lines or polylines (but it is not connected togother) how to solve this issue plz...
Dileep
Message 18 of 18
Joe-Bouza
Joe Bouza
Rail Community
