I am having an issue with export to Autocad command.
The command allows me to select my options of format, filename and location but doesn't create a file.
I'm new to Civil3d so its very possible I'm doing/not doing something basic.
The file I'm attemting to convert to Autocad is constructed from data links if that matters. (existing+proposed surfaces, alignment and sections)
Any suggestions on what could be wrong?
thanks
Sean
Solved by AllenJessup. Go to Solution.
I rarely (if ever) get the command to work. I create a copy or the drawing and use AECOBJEXPLODE. Then either Saveback or WBlock to a previous version if needed.
Allen
Allen Jessup
CAD Manager - Designer
Just trying to Export now and got the inevitable error......
