Civil 3D Forum
dwg topography to 3d solid
3 REPLIES 3
435 Views, 3 Replies
Hi. I need to create a 3d terrain solid from dwg nivel curves (contours). I tried with loft command but the lines are too detailed and my pc takes a eternity to loft just 2 lines and i have a lot of it.
I was wondering if use revit will be a good option. Can you please tell me the best way to do it and dont create a extensive 3d file?
Regards
3 REPLIES 3
antoniovinci
Start from here, sir.
in reply to: antoniovinci
before he can use that advice he has to first create a C3D surface from the contours.
tcorey
Are you using Civil 3D? If so, do as the previous poster suggested and create a Civil 3D surface from your contours and then follow AntonioVinci's link.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
