hy,
I need some help in creating an intersction between 2 ditchies like in the pictures attached.
I have created an ansembly, but its not dynamic, i have 3-4 polyline on top to put the targets for the ditch. Maybe the intersection like will change and so on.because i need to modify the width of the lane.. and so on.. Also i have created a grid, i couldnt creat the daylight intersction to existing ground between the 2 assemblies. The daylight of each assembly should stop if they meet.
In the other picture i have put interchange in wich i want to use that assembly... its a linkroad that has a ditch and intersects with the motorway that also has a ditch.
I can not attached the dwg file it is to big to be attached here.
Also there is on option of creating a subansembly in subansembly composer.
Thanks.
I am using civil 3d - 2013...
Thank you to discuss this topic!
I worked on a similar project, and I'm looking how to manage the intersaction slope area of the principale section with the ramp.
the objetive is to stop the two embankments at the intersection.
Thank you in advance for your ideas 🙂
I'm no expert on Marked Points but I think they are helpfule for this kind of situation
Joe Bouza
Thank you for your ideas
I found the following solution:
1- Create Surface from Baseline 1
2- Create a fetureline form the area of Baseline 1 That Located in the corridor intersection entre 1 & 2
3- Create subassembly That target featureline by using linkoffsetandelevation
This is not the only one, but it did the trick for me.
Thank you.
