Hello Dears
While I am doing Daylight Rounding, I have Rounding lenght issue. At similar height it is doing different lenghts. I created sub. at SAC, but, i had same result. I tried 2 ways at autocad (lenght and raidus) but everytime i have same issue. I want same straight rounding curve lenght on all way. Please Help me. @KMercier_C3D
Daylight rounding using a radius will have a varying length but you should have a consistent length if you are defining the rounding by length. I was not able to recreate your issue. If you share your .pkt file we may be able to figure out why it is being inconsistent.
My version of the daylight rounding PKT file is attached. Just change the .zip to .pkt after you download.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Hello Kati when i use your pkt, it works as below.
this is what i want what i added below always same round lenght 8 tesellations.
But when i check my crossections at some stations(not everywhere) it gives me this problem as belowfor that reason i am sending my pkt. i hope you will show a way to me.
It is difficult to trouble shoot the issue you are having with the screen shots you are providing without seeing what the existing contours are doing and what the cross section is applicable to the various places where it is providing inconsistent grading. I can not recreate your issue.
Pronouns: She/Her
