I'm using Civil 3D 2019,
Having issues with automatic hatching of pressure pipe in profile view going outside the outer limits of the pressure pipe. See attached screen clip.
I've resorted to manually hatching for now.
HMM, I can't see your image for some reason. Does it go outside on the screen, plot or both? My initial assumtion if it is the screen would be to increase the setting in the VIEWRES or decrease the setting in the FACETDEV command. This affects how curves are drawn on the screen.
Thanks, please let me know if this helps.
HMM, I can't see your image for some reason. Does it go outside on the screen, plot or both? My initial assumption if it is the screen would be to increase the setting in the VIEWRES or decrease the setting in the FACETDEV command. This affects how curves are drawn on the screen.
I typically have to download the attachments on the forums, they won't load for me.
Back to the main issue, it's on screen and plot. I had tried VIEWRES and FACETDEV without success.
Thanks for the reply!
See if you canp your drawing, I can check it out
Thanks, but no can do. Company policy and other mitigating factors.
I appreciate the effort though, thanks again.
