Civil 3D Forum
Creating a conditional sub assembly
10 REPLIES 10
Message 1 of 11
7846 Views, 10 Replies
Hey all...
I am at a crossroads with this corridor that I have to create in Civil 3D 2011, with a sub assembly that logically seems very simple...the conditions for daylight can be found in "Proposed Cross Section".  In short I have 4 fill conditions and 2 cut conditions, based on height above original ground...(there are additional requirements for guardrails and retaining walls but at this point i will settle for my slope reaching original ground)
Please, if anyone can assist me in finding a way to achieve the objective in the Proposed Cross Section without the anomalous results shown in "Sample Cross Sections", i would be really grateful.
Tim.
10 REPLIES 10
Message 2 of 11
sboon
I think I have an assembly that will work for you, and has additional options that will allow for guardrail and walls later.
I used DaylightGeneral because it has built-in options for three cut and three fill slopes.  This allows me to have one conditional test for cut and satisfy both of your cut slope conditions.  I can also use two conditional fills, one for the three high fill conditions and another for the two lower ones.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 3 of 11
sboon
in reply to: sboon
Parameters for the Cut Daylight
Steve
Message 4 of 11
sboon
in reply to: sboon
Parameters for the Low Fill Daylight
Steve
Message 5 of 11
sboon
in reply to: sboon
Partial parameters for the high fill daylight subassembly.
Steve
Message 6 of 11
in reply to: sboon
Thank you so much for your help, its good to have a point from which to start...AMAZING
Message 7 of 11
fcernst
What is your ditch foreslope requirement? Does it have to change with depth?
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 8 of 11
in reply to: fcernst
Yes,
the foreslope changes depending on the depth of cut at a at the foreslope.  However, a minimum 1m deep ditch, must be maintained.
Message 9 of 11
in reply to: sboon
Thank you sooooo much for your help.  now my corridor actually makes sense.  I cant tell you how grateful I am.
Message 10 of 11
fcernst
Yes,
I was wondering about that because your sketch wasn't clear on the ditch foreslope requirement.
This assembly arrangement keeps the ditch foreslope constant at 6:1.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 11
fcernst
What is your ditch foreslope supoose to be?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
