Civil 3D Forum
Convert drawing
3 REPLIES 3
230 Views, 3 Replies
Convert drawing
I have a quick question..I am working on a drawing on civil 3d 2014 , can i able to work on same 2014 drawing in 2013 if not what can i do
3 REPLIES 3
jporter
Yes, 2014 is the first version of Covil 3D that backward compatible. 2014 and 2013 are the same file format. You cannot do this with earlier versions.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
rkmcswain
jporter
RK is correct. Good practice, regardless if it Civil 3D or AutoCAD, is to try to bit jump back and forth between versions. The potential prooblems are numerous. If you need to send your Civil 3D drawing back to earlier versions (even between 2014 and 2013) then it appears you need to return to old faithful: http://enceptia.com/dirt/?p=1717. It's not pretty, but it works. Try to remain in one version if at all possible.
Jason Porter
www.asti.com
Rail Community
