Civil 3D Forum
Contour Label Line
2 REPLIES 2
darreng_oa
529 Views, 2 Replies
Contour Label Line
I have been creating contour surface labels, which utlize a 3-point  countour label line with grips to adjust, and this is my question:
when i create a single contour label, clicking specficially on a contour i want labeled, the countour label line with the 3-grips extends beyond several contours and thus places a label at every contour it touches.  i can manually fix this by shorting the line, but this seems very inefficient.
1. is there a setting to have the label only placed on the center grip of the three?
thanks
2 REPLIES 2
tcorey
in reply to: darreng_oa
The software makes the label line a tenth of an inch, times the scale at the time the contour label is added.
You can make your scale very small, place the labels, and then put the scale back to normal. The label lines will not change length when the labels update to the larger size.
I don't think there is a setting for this. I do it this way as a workaround.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
darreng_oa
in reply to: tcorey
A+
Thanks!
Rail Community
