Hi
I create a condition cut and fill subassembly but when create corridor not all the benches are drawn.
Solved by Jowenn.Lua. Go to Solution.
Hi @neam ,
You need to attach all your conditional to your Basic Lane. Once you update the order of your conditional then re-target all the surface then it will work. See guide images, sample dwg and <screencast link> as a guide.
Cheers,
Jowenn
Jowenn Lua | Principal Implementation Consultant | Solution Innovation Lead
Autodesk | LinkedIn
AU 2020 CES473668 ā Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 ā Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 ā Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 ā AutoCAD Civil 3D and Subassembly Composerā Real-World-Practice Tips and Tricks
Hi dear friend
I really thank you for answering my question.
šššššš
