Civil 3D Forum
Comma in Civil 3D 2007?
28 REPLIES 28
Message 1 of 29
391 Views, 28 Replies
Does anyone know how to add a comma to the square footage entry on a parcel
label style?
Oh, wait, I DO! (All thanks go to Peter Funk who gave me the procedure over
the phone and allowed me the privledge of documenting it)
Procedure and captures at:
http://civil3drocks.blogspot.com/2006/06/not-so-instant-comma-is-gonna-get-you.html
Dana Breig Probert
CADapult Ltd
Empowering Design With Innovative Solutions
www.cadapult.net
28 REPLIES 28
Message 2 of 29
Dork.
But that's a seriously nice workaround.
I know, we hate that word, but that's a good one.
Now, Dan, et al, put it in as an option!
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
Message 3 of 29
I have all kinds of other expression ideas. I am kind of an excel dork, so
this reminds me of all the crazy stuff i get excel to do. The flood gates
are open and my brains are about to spill out all over the floor. No, wait,
that is my cuppa joe right here.
Dana Breig Probert
CADapult Ltd
www.cadapult.net
"James Wedding" wrote in message
news:5213220@discussion.autodesk.com...
Dork.
James Wedding, P.E.
Civil 3D 2007
www.eng-eff.com
www.civil3d.com
Message 4 of 29
Slight revision to the method... (the current method falls down if the area
is 10,000.00 for example).
Whole Number Expression = Parcel Area / 1000
Label: Whole Number
Message 5 of 29
sorry for the ommission- I will post.
Dana Breig Probert
CADapult Ltd
www.cadapult.net
; "Inc" wrote in message
news:5213797@discussion.autodesk.com...
Label: Whole Number
Message 6 of 29
Sorry,
I sent before I finished the post. Please check out Dana's Blog for the
corrected instructions. We had a little logic error on the formatting, but
it works now.
Peter
Message 7 of 29
give me a second....
Dana Breig Probert
CADapult Ltd
www.cadapult.net
news:5213950@discussion.autodesk.com...
Sorry,
it works now.
Peter
Message 8 of 29
OK- new and improved.
Almost too easy. I was sorry not to use the FLOOR anymore, but I am sure I
can come up with something else to use it in.
http://civil3drocks.blogspot.com/2006/06/almost-instant-comma-gonna-get-you.html
Dana Breig Probert
CADapult Ltd
www.cadapult.net
"Dana Breig Probert" wrote in message
news:5213931@discussion.autodesk.com...
Dana Breig Probert
CADapult Ltd
www.cadapult.net
Sorry,
it works now.
Peter
Message 9 of 29
Works great, unless you have 1,000,000 square feet (which is only 23
acres)...
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
news:5213194@discussion.autodesk.com...
label style?
Dana Breig Probert
CADapult Ltd
www.cadapult.net
Message 10 of 29
and in that case, you need to make another label and expression for over
1000000 (1,000,000) sqft.
Expression Millions: Floor({ParcelArea} / 1000000) this would return "1" for
a million.
Label:
Copy the new label, and add this expression label in front, with no decimal
places, and a comma in between.
However, this only works up to 1,000,000,000 sqft, so for those billion sqft
parcels, you'd need another label.
Peter Funk
Message 11 of 29
did you see the part about using your brain ? (hehehehe)
Dana Breig Probert
CADapult Ltd
www.cadapult.net
"Scott McEachron" wrote in message
news:5214353@discussion.autodesk.com...
acres)...
sm
Scott McEachron
label style?
Dana Breig Probert
CADapult Ltd
www.cadapult.net
Message 12 of 29
I haven't explored this stuff yet (heaven knows I'm swamped with what I have
now). Does the expression builder have 'if-then-else' statements as in
Excel? If so, it would be easy to examine the number and determine if it is
over xxx digits and then would apply rule one, else rule 2. I don't know,
maybe this is way beyond the scope of the expression builder.
Rick
news:5214516@discussion.autodesk.com...
Dana Breig Probert
CADapult Ltd
www.cadapult.net
acres)...
sm
Scott McEachron
label style?
Dana Breig Probert
CADapult Ltd
www.cadapult.net
Message 13 of 29
You can do the if then else, but you can't return a string, so it doesn't
help.
Cheers,
Peter Funk
Message 14 of 29
It looks like the blog is gone. Can you post the work-around in a different way?
Thanks!
Message 15 of 29
The blog is up just that the link is old, look in the archives for June of
2006 and about half way down the page is the post.
Murph
The world is not FLAT so why is your GIS data?
http://mappingitout.blogspot.com/
wrote in message news:5434474@discussion.autodesk.com...
way?
Thanks!
Message 16 of 29
How does setting up expressions in label styles affect the redraw speed? In other words, is the result of the expression saved and used for subsequent redraws, or is the expression in the label style evaluated every time I zoom in or out with the mouse wheel?
Message 17 of 29
dana.probert
i had to rewrite the post---- here is the direct link to the comma hack on Civil 3D Rocks
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
Message 18 of 29
dana.probert
i haven't noticed any hangs to speak of, and I use heaps of expressions in all kinds of labels.
Dana Probert, P.E.
Message 19 of 29
Thank you - that was very helpful!
Scott
Message 20 of 29
I have worked out a different way of doing this, you get the same result but you could scale it to work for over 1 million SF lots. It uses 2 expressions and then you combine them in the style editor and put a comma between them.
Use Expressions like this
Thousands Only
TRUNC({Parcel Area}/1000)
Hundreds only
{Parcel Area} - (TRUNC({Parcel Area}/1000)*1000)
Then combine them in the contents editors by using thousands only with precision set to 1 then a comma then hundreds set using what ever precision you like.
Again for less than 1000 SF lots you get an extra comma and would need a different style and over 1 million you won't get the first comma but you could set up another for higher numbers.
Just a little different but this way you can display numbers to the right of the decimal place if you like.
Jamey Westmoreland, P.E.
CAD Manager
WIthers & Ravenel
Rail Community
